Nashbar Carbon Fork Review
big ring
Nashbar 1" Threadless Carbon fork with Alloy Steerer
Shipping was reasonably quick and it was well packaged. I took it to the LBS to cut the steerer tube and install a star nut.
Everything seems great after tonight's short ride. The rake is greater at 43mm than the stock 28mm, so the wheelbase is a bit more stretched out and I no longer have any toe overlap.
Handling is noticeably more precise - almost twitchy. The biggest benefit is when I am braking. The stock fork is decent but it is not designed for braking since it's a track fork. The fact that it was drilled for a brake seems to be an after-thought. The stock unicrown fork used to flex so much under braking that the axel would move back over 1" under heaving braking. This is gone with the new fork.
Benefits include - stiffness, weight reduction (almost a pound), better braking control and much more comfortable ride.
Cons would be borderline twitchy handling (super-precise) and aesthetics. Aesthetics is up in the air - I like the all chrome look for it's retro appeal but now my Pista looks more modern. Pictured with a Krysium Elite front wheel.
re:member
Bikes: unknown make TT bike, fixed; Romet Sport, gone; titanium Pinarello gone;Colnago with Campy C-Record/Super Record,on it's way; Funny Gianni Motta; Buehler track, Polrad track chrome; titanium MTB on 28'', fixed; Tri Wheeler, fixed
I have chromed the carbon bianchi fork - had I given it more time to settle, it will be harder than regular paint (I know, I tried to remove chroming half a year after application)
big ring
Update - I rode a century (100 miles) on the fork over this weekend. It was much more comfortable than the stock fork. Whoot whoot!
fails just as quickly
Thanks for the review. I just put in the order for one to replace the stock fork on my IRO jamie roy. If I like it, I might buy another for my specialized.
Are there any nashbar logos on it?
big ring
It perfectly plain. The dropout is painted black too - that's a nice touch. The crown has a black paint which fades to nude carbon.
big ring
Here is the most recent view with my new carbon fork. It's pretty road worthy in it's current state - I do a lot of training miles on this bike. The saddle to bar drop is a bit excessive now, but it sure is badass with over 6" of drop.
[IMG][/IMG]
[IMG][/IMG]
https://www.pedalroom.com/members/iamtim
Boston did not sob
Thanks for the review, I'm definitely itching to pull the trigger on one of these...
Bikes: 05 Bianchi Pista, 07 Niner Air 9
What did you use to black out the world champion stripes on the pista? Electrical tape? Thats what I've got on mine because it looks soooo much better without the color. Still a little jank but whatever.
Boston did not sob
No it does not contradict.
The increased rake moves the front tire out, thus the longer wheelbase.
With the front wheel moved out, the trail of the bike is DECREASED, thus the more twitchy handling. Look up Sheldon Brown's site for a full description of trail, rake, etc.
big ring
I know what you mean - what I meant is that the increased stiffness of the fork seems increase the handling precision. I can't say if that is from the increased rake or the increased stiffness (both of which are fact) but it's certainly more precise than the stock steel fork. Does that make any more sense?
Electical tape worked fine and it looks like paint unless you are a foot away.
Thanks! I was using a 3T Mutant 120mm stem and I decided that was too long for the bullhorns. So I swapped it out for the stock stem which has too much angle on the stem. The 3T was close to 0 deg rise and the stock is like -15 deg rise. So if I flipped it, it would be too high up.
You mention the fact that I am running a lot of spacers - that brings up a point. Getting a new fork allows you to increase that space over stock. I am running about 20mm longer steering tube than stock.
Why not flip that stem to re-level your seat/bar ratio? You've got it jacked up with a bunch of risers anyhow. That bike is looking sweet!
big ring
There is only one option for length. I'm not sure where you are getting 160mm from - that's only about the length of the headtube.
It's a long steerer tube and you have to cut it to size and install a star-nut, which is not provided.
so i guess get the long one? haha how confusing, also what is the star nut used for?
big ring
What year is your Pista? If it's 2002(ish) or newer than it should have a threadless steerer.
This is the product that is being reviewed in this thread. Are you sure you don't have a threaded steerer tube? Not to be rude, but if you don't know what a star nut is, why are you buying a fork?
im not buying one, i just wanna know for future reference. you know learn something and see if i want to get it in the future, my pista is a 2006
big ring
In that case this fork will work on your bike. Just select the 1" and not the 1 1/8" size. I had my LBS cut the steerer because I don't have a cutting guide tool.
Sharp Volcano Soul Mate
Min, where did you get the steerer tube cut down? I'm in PDX too and I'm considering picking one of these up myself. And how much did it cost?
