The bike named Mu
uberNEWB
Bikes: Haro V2 [rip / stolen], PEUGEOT '93 SELECT
The bike named Mu
Timo, before you even spout off anything about my TT bars not being cross legal ... that depends if its an amateur race / accepted locally ... and also I do have my drop bars that I'm prepping ... On my drops I will be using tektro cross top levers w/ shimano exage levers.
For now... here are a few pics of the almost final bike. Just need to put the FD on and chain and cut the excess wires.
I listened to my gf and left the paint job in so-so quality for now (seeing as Montreal thieves are all arseh*les)
Before....
After stripping the paint and viewing the parts pre-installed on
After the 2nd coat of rattle can...
3rd coat of paint and drying between coats...
After....
I got a bit of house cleaning / stuff to do so I'll prolly post the in between photos of while I was building this bike either tomorrow or monday... I'm off to a wedding this weekend. Cheers !
Specs:
Shimano 105 groupo minus the rear caliper which is a long reach exage caliper.
Specialized mtb SPD pedals
Shimano Ultegra 600 downtube shifters / will be upgrading to kelly take-offs
Nashbar TT bar with tektro r4.0 reverse TT levers
Ritchey SpeedMax Pro Comp tires 700x35c (yes I barely have clearance thats why I have the exage caliper on the back)
Veluta Typhoon rims
Nashbar camo cork handlebar tape.
Also I am giving away my sugino 172.5 50t crank which needs new pedals and a good cleaning its a square bolt crank, for either local pickup or just pay the delivery charges... PM me
Before....
After....
Specs:
Veluta Typhoon rims
POWERCRANK addict
not my taste - would have gone for disc brakes but it looks as though you put a LOT of work into that.
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Before....
After....
Specs:
Veluta Typhoon rims
Before....
After....
Specs:
Veluta Typhoon rims
uberNEWB
POWERCRANK addict
good job and no problem
That's an awesome build. I've got a few questions though (as I've got an '82 Peugeot PH12). How did you fit 35s on there? I had some Michelin cross tyres on mine which are 700x32 (but more like 35s) and they would rub on the stays ever so slightly. I didn't have any trouble fitting them between the calipers though as long as I put the wheels on with flat tyres. Would you mind posting a pic of the clearances of the tyres?
I'd been thinking of using my Pug as my spare cross bike but I wasn't sure how well the old brakes would cope with the rain/mud. Have you had the chance to test yours out in poor weather?
uberNEWB
nope... I need to put the FD on and the chain and inflate the tires...
clearance on the rear is a good inch
on the front its about maybe 1-2cm max but I need to swap out the fork for a cross fork and cantis will give for another few cm of clearance...
I'll take photos... The front tire is really really close almost rubbing.
The rims I bought said specifically 700x35 and I just bought tires to match I should prolly go with 32s or even 30s... I had put the 35s on my 25 rims and they didnt clear at all... just made one huge tire... I guess the rim spread the tire out the way its supposed to be.
uberNEWB
ok so the front derailleur is on and the chain locks when I coast in reverse. seems like I have a little rear wheel misalignment. Gotta get it adjusted 2-3 mm. and I'm good to go.
uberNEWB
UPDATE:
took Mu out for its maiden journey and all I can say is zoom zoom...
with the front tire rubbing I decided to swap out my cross tires for my road tires. The rear has a LOT of clearance and the front is just shy from touching.
uberNEWB
POWERCRANK addict
and, no, I'm not jealous about the speedhub, honest
I'm hoping one of my future bikes will have a speedhub, preferably a nicolai g-boxx bike - when I have enough clams
