Biodegradable Chain Cleaner?
Is there such a product that actually works? The Performance stuff I tried is really weak. Although gasoline or parts cleaner are probably the best solvent to soak a dirty chain in, I want to find a product that actually works and is safe to flush down the toilet. Any advice?
Bikes: Stowe(3), Terry(1), Cannondale Tandem (1)
I like Mineral spirits, which I throw on the weeds out back and it evaporates. Biodergadable? Not really but it works the best of any chain cleaner I've tried.
Sheldon
Sheldon
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
Simple Green Automotive Degreaser. Non-toxic and biodegradable. I buy it by the gallon at around $10 and use it by the quarter cup diluted in two cups of water. So it works out to be really cheap too. Cheaper than gas or mineral spirits, in fact.
Living in an apartment building, the only place I have to work on my bikes is the kitchen or the bathroom, and then pouring used cleaner down the drain. Simple Green is safe for that.
Quoted: 1109 Post(s)
Liked 1,200 Times
Any citrus based degreaser. There's a million. My LBS happens to sell cans of "finish line" brand and it works great. Read the lable if you're uncertain about biodegradability. When my can is empty, I'll probably get a gallon of the Simple Green product recommended above.
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Body By Nintendo
Location: Videogames ruined my life. Good thing i have 2 extra lives.
Bikes: Giant TCR2, Giant TCX, IRO BFSSFG SE, Salsa Casseroll, IRO Rob Roy.
Simple Green, undiluted at full strength.
However, i use paint thinner to clean my cassettes on occasion. I take it to the hazardous waste disposal/recycling center with my used motor oil.
Liked 1,200 Times
Originally Posted by DMF
It kinda works. For a chain don't follow the directions on the bottle — use it full strength. The other "green" degreasers aren't going to work any better.
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
Roccobike BF Official Thread Terminator
My bike's better than me!
Bikes: (2) Moots Vamoots, (1) Cannondale T2000 tourer, (1) Diamondback Response Comp mtb
ZEP Citrus Degreaser.
$8.97/gallon @ Ye Olde Home Depot
(Grouchy)
dumonde tech citrus degreaser has worked the best for me. and it has a nice pleasant citrus smell. the thing is, while the degreasing agent might be bio-degradable, the crap it cleans off the chain may not be, and may not be safe for wildlife or ground water in your are. flushing it down the toilet is probably not the best idea for any chemical, biodegradable or not.
If you are worried about the environment fill a can with oil. Let the chain soak for a day, put something inside to keep the chain off the crud on the bottom. If you know what you are doing heating the oil a bit helps. After years of doing this the oil will be to cruddy to keep using. Bring it to your local recycling/garage location.
Two at a time is more fun
Bikes: 2006 Burley Tosa
Golden Degreaser. Find out more at https://www.purpleextreme.com. This is not an advertisement, just a satisfied customer. I was skeptical at first but willing to try it. Worked like a charm. Took every bit of grease off the gear cluster and der cogs. I would recommend it to anyone.
Out of all the things I've lost, I miss my mind the most.
With any of these degreasers can anyone rate other important features 1. residue on chain and bearings and 2. "dry" lack of atraction of grit? A great degreaser may prevent the next application of lube from working thereby accelerating wear.
When does one clean the chain? Appearance or a noticeable shifting performance?
Pwnerer
Formerly Known as Newbie
--J
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
FinishLine Ecotech II is a biodegradable degreaser that will clean the stink off an ape. I use it full strength for true nastiness and dilute it for the mildly ugly.
Just ride.
For the worst things, mineral spirits do work better than Simple Green, etc. But rather than tossing it, you can keep it in a jar and re-use it. The crud settles out to the bottom and you can ignore it if you don't slosh things around too much next time you use it. Or just pour into another jar, leaving the crud on the bottom of the old one.
What about acetone? I've heard it is relatively eco-friendly (compared to, say, kerosene) and not exceptionally toxic (though I still wouldn't breathe or touch the stuff or use it near an open flame). Plus it leaves no residue on the chain. It's very volatile but I looked into it a bit and I couldn't find any references to it being a particularly strong greenhouse gas.
The chain is always visually clean, silent and shifts perfectly. I measure the chain often and replace when worn.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Do you use 3 in 1 type or a fancy chain specific lube? I've used a number of chain lubes that all tend to get dark and sticky.
Bikes: 2003 Giant OCR2
However, I'd be surprised if it did all that capable a job at dissolving heavy grease.
Software for Cyclists
Bikes: Trek 5200, Specialized MTB
Just be careful to not get any product that contains phosphoric acid.
I purchased some "Greased Lightning" once at Home Depot because they were out of Simple Green, not realizing about the phosphoric acid. The stuff was tough on grease, but the phosphoric acid "etched" the finish on my derailleurs, etc.
Aluminum + Simple Green
Simple Green used to be, 5 years ago, a no no because it caused corrosion to aluminum parts on aircraft. Have they changed the formula
