Deep V's
Deep V's
Old 06-22-07, 11:29 AM
Seek the Joy
Deep V's
Would 32 hole velocity deep v's make good touring wheels? IT seems like the deep profile would make them very strong, am i deceiving myself?
ivegotabike is offline
Old 06-22-07, 12:03 PM
Liked 2 Times in 1 Post
32 on 26" would make strong wheels. Hard to see why one wouldn't go for 36 spokes. One of the nice things about that make is they offer some 40s and 48s. The deep Vs do have more of a girder effect and it does make for stiffer sections and stronger sections between the spokes. Tourists are still carrying extra spokes, aramid spokes, so the spoke problem hasn't disappeared, more spokes are still better. It depends on how close your touring mode is to just regular riding or whether it is more towards an expedition mode, and how well your wheels are built. Elite built wheels make a huge difference.
NoReg is offline
Old 06-22-07, 12:42 PM
Seek the Joy
36 spoke you say. 700c would be good at 36 spoke?
Old 06-22-07, 05:53 PM
Destroyer of Worlds
kyledr's Avatar
It's too narrow. For touring from Velocity you want the Dyad. Sadly, I believe it's lighter than the deep V, but it can take wider tires.
kyledr is offline
Old 06-22-07, 06:51 PM
o.O
Seggybop's Avatar
I have the 26" version and I've been using some extremely wide tires (2.35" big apple). I think the 700c version is narrower by a few mm, but I know a couple people who've been using 700x38 tires without any trouble. ymmv.
Seggybop is offline
Old 06-22-07, 07:31 PM
Seek the Joy
what would be the ultimate touring rim in a max of 36 spokes?
Old 06-22-07, 08:08 PM
Year-round cyclist
I have great success with Mavic A719.
Michel Gagnon is offline
Old 06-22-07, 10:45 PM
Zen Master
Miles2go's Avatar
Bikes: Cervelo R5 - SuperSix
Quoted: 75 Post(s)
Liked 89 Times in 42 Posts
I'd go with the Dyad based on Peter Jon White's experience. He prefers it over the Mavics and says the Dyad is "virtually impossible to crack".
I've heard the 719 is good though. In my experience Mavic makes some great rims and some with tendencies toward cracking at the eyelets. I've beat the daylights out of some low spoke count Mavic road racing wheels and they truly amazed me. On the other hand I've had one set of Mavics used for mountain biking and one set for touring crack.
Ron - Tucson, AZ
Miles2go is offline
Old 06-22-07, 11:29 PM
totally louche
Bekologist's Avatar
Bikes: the ever shifting stable loaded with comfortable road bikes and city and winter bikes
Liked 10 Times in 9 Posts
Dyads.
Bekologist is offline
Old 06-22-07, 11:59 PM
Alex DH22.
On 700C you want a minimum of 36 spokes. Sure you will hear stories about wheels that took a trashing at some tiny number of spokes. 36 is really the minimum for light shallow rims like the legendary MA2, so one knows it provides adequate spoke support. If you peel away spokes you "need" to go to rims that have structure. That seems to be Brandt's view.
If you are buying all new parts go for 40 on 700C, though most people won't want to queer the resupply situation. I basically build to tandem numbers, that's my weight, and the upper end load weight, it could be as high as 300 pounds on the bike. The fact is that tandems are just bikes, like most bikes they may not get riden all that hard or long so I don't think tandem numbers are crazy for touring bikes if your weight is 200 or up. If you are 150- 200 with no more than 50 pounds gear, go 36 spokes, and if you are 150 down you could go lighter on the spokes, though I don't actually see the point. All estimates are for 700c go down one measure for 26". I don't try to save weight by reducing the number of spokes, you could get better performance by switching to a light inner tube (not recomending that either). Wheels are the defining part of any bike, and the last part you should compromise.
I'm feeling bad about all this right now, I just bought a Rohloff Speedhub which is 32 spokes. I'm going to a 26" rear wheel and the flange is really high on the Rohloff. I am assured that I can't break it. And that is probably true, though I don't much like it.
NoReg is offline
Old 06-23-07, 12:57 AM
Destroyer of Worlds
kyledr's Avatar
38s on Deep Vs sounds like trouble to me.
kyledr is offline
Old 06-23-07, 01:01 AM
Destroyer of Worlds
kyledr's Avatar
On a 32 hole rim with a rohloff, I'd be more worried about spoke breakage. I don't know how much concern you should have over that, though, because I don't know jack about MTB stuff/sizes.
kyledr is offline
Old 06-23-07, 01:17 AM
+1
Cyclist0383 is offline
Old 06-23-07, 07:55 AM
Sebach's Avatar
Bikes: Surly Long Haul Trucker
I run Velocity Deep-V's in 26", 36h, built by Peter White on my LHT. He told me that he would not worry about giving me (200 lbs, and fully loaded) a 32h Deep-V rim for touring. Apparently, he uses 36h for tandem MTBs if I remember correctly. I still went with 36h just because I figured that 4 extra spokes wouldn't kill me and would be a good idea. I ran Continental Travel Contacts (26x1.75") across Canada last summer without so much as a flat tire or a bump on the rim.
Sebach is offline
Old 06-23-07, 12:05 PM
Seek the Joy
roholffs only come in 32 hole... guess they havent been having much trouble.
Old 06-23-07, 12:07 PM
Seek the Joy
thats actualy why i was planning on buying 32 holed rims is so that later i could cut out the hub i buy now and put in a roholff. When i get some (lots) money.
Old 06-23-07, 01:19 PM
Bikes: Trek 1500 & Schwin Traveler
You want 36 spokes for touring minimum. Also, drill the rims for schrader. You'll be happy you did.
dang133 is offline
Old 06-23-07, 03:24 PM
Destroyer of Worlds
kyledr's Avatar
Yeah, I was wondering about drilling. My touring bike is schrader, and it irks me... I so love my slender presta valves. Man I'm a dork.
kyledr is offline
Old 06-24-07, 09:16 AM
Sebach's Avatar
Oh yeah, if you do run Presta valves on your Deep-V's, you might want to think about either long-valve tubes or valve extenders or something. I have Conti tubes in my rims right now and the Presta sticks up just enough to "lock onto"... but the pump has to be perfectly straight, heh.
*edit* I guess the same would go for Schrader valves too, I never really thought about it.
Sebach is offline
Old 06-24-07, 09:43 AM
Zen Master
Miles2go's Avatar
Quoted: 75 Post(s)
I don't drill my rims for SVs and have never regretted it. I'm certain that I never will.
On the other note, Peter Jon White and Schwalbe USA sell tubes with longer valves.
Ron - Tucson, AZ
Miles2go is offline
Old 06-26-07, 11:27 PM
convict
aussie_SS's Avatar
Location: land of "throw another F'ing shrimp on the BBQ"
I thought that having SVs, was that you could put extra air in your tyre at a serv'o?
aussie_SS is offline
Old 06-26-07, 11:39 PM
cyclezealot's Avatar
Bikes: Klein QP, Fuji touring, Surly Cross Check, BCH City bike
Quoted: 1485 Post(s)
Liked 73 Times in 64 Posts
I have had two sets of Deep V's on my commuter bike. Twice the nipples were pulled through the rims. I'd keep a lighter load on the Deep v's. Agree with the Mavic's A 719. Rugged.
cyclezealot is offline
Old 06-28-07, 09:21 AM
I built a front wheel using a 700 Deep V and a Shimano dyno hub....it works great so far...i switch the wheel between my commuting fixie and my trekxtracycle (trek w xtracycle on it ...i'm going to take the trek (sans xtra) on a tour of oregon this august.....
xcapekey is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
