How many broken spokes would be dangerous?
Destroyer of Wheels
36 spoke, 27" wheel. Just noticed 6 were broken, three on each side. Problem? About go to on a 60 mile ride, meeting up with some people in a few hours. I ordered a new handbuilt wheel but it looks like it's going to take a bit longer than it was expected.
The Almighty Clyde FAQ || Northeast Index
eTrex Vista References || Road Reference
It's the year of the enema!
Bikes: 2005 Windsor Kennet, 1982 Raleigh Super Course
It doesn't sound good to me. I am 210 lbs and when I broke one spoke on my rear wheel with a 32 spoke count it went way out of wack. Had to remove one of my brake pads to get home. I am kind of amazed that the wheel is still relatively true with six broken spokes. Are you sure they are broken? I wouldn't risk it unless you have a sure way of getting back because I can't see how you are going to make it. It sounds like you have an old bike. Can you borrow a wheel from someone who might have an extra wheel or bike?
Destroyer of Wheels
It wobbles but I was able to bring it in enough that it didn't wobble nearly as much as it did before.
Unfortunately I don't think there's anyway back - 30 miles one way. So pissed - was planning on getting a ton of miles in this weekend
Perma-Clyde
Bikes: Trek Hybrid 7200
Problem? 6? Hell ya! Mine went outta whack once two popped. I doubt you'll go 60 feet, let alone 60 miles.
Just curious, how long have you been riding around on these broken spokes?
I wouldn't go down the driveway on six broken spokes...I'm surprised the thing will go around at all, and I think you're guaranteed to taco it if you ride.
Looking longer term, you might work on developing some sensitivity to the bike. I don't think I've ever even SEEN a wheel with six broken spokes, unless the derailleur shifted into it at speed. It's very unlikely they all broke at once, so you must've been riding around with five broken spokes, and before that four, and before that three....
Chubby super biker
I agree with all comments above, and echo your feelings. My new roadie has been busting spokes like crazy for the past two weeks, and I've finally given up on the crap machine built Bontragers it came with. My handbuilt rhynolite will be done on Monday or Tuesday, so until then I'm living with a lack of mileage.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Northern Minnesota
Bikes: 2005 Fuji Crosstown, 1984 Raleigh Racing USA Competition, 197? Fuji Cambridge III
See - this is why you need to have at least 3 or 4 spare bikes!
Seriously, no way would i ride that. A pair of spokes on the rear wheel pulled out of the hub last fall on a ride, and there was no way i would even try to ride it home. A nice 6 mile walk in the evening uses different muscles than riding.
Senior Curmudgeon
Bikes: Varies by day
Quoted: 5 Post(s)
A spare set of wheels isn't unreasonable if you want to make sure you don't miss rides. When ONE spoke breaks, it is time to have the wheel repaired. Use a spare wheel until the first returns. As the spoke count goes down (OR the number of spoke-crosses decreases), the criticality of each spoke increases. Spare wheels are DIRT CHEAP on e-Bay. Even a machine-built set will work. Once your LBS tunes up the wheels, their reliability goes up. I'd never ride a wheel with even a single broken spoke. I've had a wheel disintegrate under me at speed. I have permanent damage from that accident. DON'T RIDE DAMAGED WHEELS! Just my two-cents...
Nishiki road bike, Raleigh road bike, Electra Cruiser Lux 7d, Electra Townie 3i, Electra Townie 1, Whatever I find today!
Perma-Clyde
Senior Curmudgeon
Quoted: 5 Post(s)
Originally Posted by (51)
God, what does that sound like? Are there any warning signs (pops, twangs, squeaks)? This is a concern to me.
Destroyer of Wheels
Thanks everyone - I decided not to ride it. Started riding down to the bike co-op to see if anyone was there but the wheel was getting worse and took my mtb for the first 15 miles and turned back. Fell down a flight of stairs and knee was getting worse struggling against the bike and the hills.
Last Sunday I went for an easy 50 miles, no problems. Tuesday I went for a ride and hammered for 40 miles, climbed some hard hills, pushed it on the flats. Kept hearing pinging sounds along the way. Before I went I stopped by the shop to get a new wheel since it was hard to get true and had a flat spot - he's hooking me up with a hand built one which I'm excited about. Should have been here Friday but there's a problem, blah, blah blah. I checked the wheels 20 miles before those two rides and there were no broken spokes so it happened on one of those two rides, my money's on the hard ride. Fast ride, uneasy road surface....
This is the bike I've been fixing here and here. It's been outside in the elements for at least 2-4 years and probably longer, it's over 20 years old, and has original wheels. So I'm not all that upset that the wheel started to implode. I find it funny I had the new one ordered first - sixth sense is funny that way
Sidenote, was reading my first thread about fixing it up and found this little ditty:
I forgot how many loose spokes there were - but I'd put money those 6 broken ones came from those original 8 ones
On the way over I heard some creaks coming from the rear wheel. When I checked sure enough there were about 8 spokes really loose. Tightened them and completely screwed up the trueness. Had to get a bit of help getting it to a rideable point (including slamming the rim on a table which surprisingly helped quite a bit to release tension) - will play with it more so I can concentrate on repacking the hubs and bb.
Makes It Look Easy
Bikes: I own three.
One broken spoke is too many. If I'm at work and I pop one (and don't have a replacement), I usually just twist it on real tight around it's neighbor. It'll work in a pinch, but you should get it fixed asap.
When one goes, usually more are to follow. Even with one broken spoke and a couple loose spokes you can taco that wheel REAL easy. I've done it before. It's not fun.
Break spoke on ride - Wrap broken spoke around adjacent spoke, open brake callipers ride home slowly and carefully by shortest route.
Broken spoke before ride - remove wheel, take to LBS for repair. Sulk.
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Pfft! ONE broken spoke is too many. The wheel is built based on tension. One broken spoke will throw off the the tension of the remaining spokes!
Destroyer of Wheels
that was 3 spokes, shudder to think what 6 would be like. Absolutely no way I would be riding it.
