Nashbar vs Profile Air Wing Bullhorns
For those of you who poo-poo Nashbar stuff, just wanted to let you know their bullhorns are actually pretty good. I have both Nashbar and Profile's oversize bullhorns and they have identicle weights even though the hand extensions on the Nashbars are about 1" longer. They both have the same subjective stiffness, and look about the same quailty. Just thought people may not feel so disinclined to purchase them with this tidbid of information.
Differences:
Internal cable routing exit is in a different position.
Nashbar hand positions are about 1" longer (good for some, I like a bit shorter)
Profile has a wider center section designed to accept clip on aerobars
Similarities:
Fit and finish are the same
Weight is the same (within 5 grams)
Stiffness feels about the same.
Differences:
Similarities:
Electrical Hazard
Bikes: a bunch.
I have the earlier Nashbars (no flattened top section, no internal routing).. and I really like them.
I just wish they were narrower, or pointed inwards like the Syntace ones.
Originally Posted by jciv03
Dooooh!!! I just received my Nashbar OS bars, and I thought the center section would've been wide enough to fit aero bars!!
Originally Posted by chunts
if the nashbars are an inch longer but they weigh the same, wouldn't that imply they are thinner?
The Profiles say they are Double butted,... leads me to think that Nashbars may be straight gauge but no less stiff... or heavy
Originally Posted by DannyRocks
I've used the non-OS versions of both, and found them both lacking.
These look pretty nice! My chop n flop drops work but eventually I'd love some real bullhorns. Glad Nashbar has some nice ones!
By the way, I have the Nashbar clip on aerobars (really just a kind of bar extension, they don't come with arm rests), and they're meant to clip to the smaller bar diameter, not the larger where the stem does. How would those work with these bullhorns?
https://blicksbags.com/
Originally Posted by Hirohsima
Can you be more specific? I have used Profile Air Wings, Air Wing T2, Nashbars OS, Ritchey Comps, and some entry level syntace bars and found only super minor differences between all of them. It came down to fit for me, and all but my current T2's had a bit of a drop and that is why I switched. What did you find so lacking?
Bikes: 2010 Tarmac SL, 2013 Fairdale Weekender, 2013 Fairdale Coaster, 1995 Specialized M2 Pro, 1972 Schwinn Heavy Duty, 2014 Surley Long Haul Trucker
I have the Profile Air Wings. Me likey. But I've never used anything else so I can't compare.
