$17 MTB frame, shipped
NFL Owner
I just ordered this frame this morning. I figure that for less than $20, I can't go wrong.
Proof that it cost less than $17:
I spent most of the rest of the day looking at parts for it, and have come to the realization that a $17 frame doesn't necessarily equate to an inexpensive bike.
The funny thing about the frame is that they're selling it on eBay with a starting bid of $9.99 plus $30.99 shipping, or Buy It Now at $19.99 plus $30.99 shipping.
Bikes: Trek 1000, two mtbs and working on a fixie for commuting.
Wow. Good find, even if it sucks really bad.. its only $17 shipped.
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
Hope this helps.
Roccobike BF Official Thread Terminator
NFL Owner
I already have the following:
That means all I'd need is a fork, brakes, seatpost, stem, seat, cables & pedals.
Since I'm wanting to get the Catamount repainted, I'm considering moving the parts from it to the new frame while it gets repainted.
And from the looks of the dropouts, I'm thinking I might be able to go SS with it. By utilizing some existing parts, I should be able to get it running fairly cheap.
And I've also considered hitting a few pawn shops in the area to look for hidden treasures that can be stripped/recycled.
But I'm not in a hurry.
- a set of Deore LX 8-speed hubs laced to Mavic 221 rims (with tires)
- a Tioga Prestige handlebar
- DiaCompe brake levers
- SRAM X-Ray Gripshift
- a pair of OURY grips
- Deore LX RD & top-pull FD (in the correct clamp diameter)
- 600 Ultegra 170mm double cranks (yeah, I know they're road cranks, but they're paid for)
- bottom bracket (unless the Shimano one I've got works, but I doubt it)
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
Except for the non-looped stays, it reminds me very much of the old Yeti Ulimate:
Good snag, monogodo. ediscount bike is an interesting company. They get a lot of closeout OEM stock from diverse sources. They've had some incredible buys on K2 frames. Wish I'd snagged a raw aluminum cruiser frame when they were blowing them out for about $25 a few years ago.
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
That's how I roll..
Long haired freak.
Bikes: 2011 SE Old Man Flyer.
I learned how to ride a bike on a hot pink Nishiki Alien with jelly bean stickers and 24" wheels...
"the bus came by and I got on, that's when it all began...there was Cowboy Neal at the wheel of a bus to never-ever land."
NFL Owner
Originally Posted by While At Rome
your call, but by the looks of the welds on that bike, catastrophic failure is right around the corner.
NFL Owner
Moar cowbell
Quoted: 29 Post(s)
Liked 6 Times
Originally Posted by Raiyn
I learned to ride on one of these
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Hey, that was my second bike! (minus the mutli speeds). Columbia Playboy . . . even had a 'dual-crown' fork, which was cool but made it heavy for popping wheelies. My first bike was a 24" JC Higgins.
Moar cowbell
Quoted: 29 Post(s)
Liked 6 Times
Playbike Mine was the single speed with the regular fork. I still have it back at the parentals. It needs a good restoration job, but it's all there.
Playboy was the little-bit-earlier predecessor to the Playbike. Oh boy do I remember that - - my friends gave me no end of razzing for that. Maybe part of why Columbia changed the name. And the fuggly sissy bar that wasn't cool like the Schwinns:
Moar cowbell
Quoted: 29 Post(s)
Liked 6 Times
Ahh. I suppose a few moms got together and bit¢hed about it. Imagine riding that puppy during the 1980's BMX boom think you got crap? Mines still got knobbies and a BMX bar on it. (Yes we kept the ape hangers)
i can jump very high
after you have put 2 or 3 hundred hours into welding manifolds for cars that have to withstand more than 1200 degrees u know what welds are good and bad.
cant really tell because it is painted, judging from the bubble like shape of the welds on the head-tube it looks like it is mig welded.
the way to tell a strong well done weld is that is is for the most part flat or at a 45 degree angle with the 2 peices it is holding together. this shows that the heat penerated the metal enough to not only "weld" then together but also fuse them somewhat where the rod cant reach. when u get a concave weld it means that the heat to thickness was incorrect and u are heating up the metal too much. Not enough heat in the weld results in a bubble looking weld. this is basically just the physical weld holding it together. this is the weakest and worst thing to have. if ur bike was made by a reputable company probably 9/10 of them use machine tig welders which will do a perfect weld as long as there are no problems with the metal.
basically, judging by the quality of the welds on that frame, u probably would be better off building urself a wooden frame with screws and glue. might last longer.
after you have put 2 or 3 hundred hours into welding manifolds for cars that have to withstand more than 1200 degrees you know what welds are good and bad.
the way to tell a strong well done weld is that is is for the most part flat or at a 45 degree angle with the 2 pieces it is holding together. this shows that the heat penetrated the metal enough to not only "weld" then together but also fuse them somewhat where the rod cant reach. when you get a concave weld it means that the heat to thickness was incorrect and you are heating up the metal too much. Not enough heat in the weld results in a bubble looking weld. this is basically just the physical weld holding it together. this is the weakest and worst thing to have. if your bike was made by a reputable company probably 9/10 of them use machine tig welders which will do a perfect weld as long as there are no problems with the metal.
basically, judging by the quality of the welds on that frame, you probably would be better off building yourself a wooden frame with screws and glue. might last longer.
Dis Member
Long haired freak.
