brakes on non-machined rims?
babyjuniorsonofa*****
Bikes: '83-'84? Nishiki Prestige
i'm looking to buy a wheelset off eBay. they are non-machined, but i like to use a front brake. can i get away with using a brake on a non-machined deep rim? is this a really bad idea? what kind of problems would it cause?
griffin_
Bikes: raliegh "too lazy to make my own" rush hour
until your brake pad wear off whatever finish or paint is on there they won't be all that effective and even when the paint is gone they probably won't brake as well as on a machined rim
other than that it will be fine
kevinindisguise
Peter White usually has good info. This page(about 1/3 of the way down) says:
"The rim on the right is painted Egglant Purple. So is the rim on the left, but it has had the paint and an extremely thin layer of metal machined off the braking surface. This results in a very smooth surface for the brakes providing good control and no thumping of the brakes with each revolution of the wheel. Also, brake pads don't work well on a painted surface. Brakes will work well on an anodized surface, so you can use the non-machined anodized rims with caliper brakes. But your brakes will work better with the machined sidewalls. The important thing is to never use a rim brake on a non-machined rim that has a painted finish. Anodized is fine. Painted is not ok. So if you're choosing a painted finish and you'll be using rim brakes, be sure to order a machined sidewall rim."
I'm sure there is more info out there, but this would be good enough for me.
i have a set of the anodized blue deep v's and when i use the breaks hard then it squeals pretty loudly. I am told that squeak will go away after time. i mostly try to control my speed with my legs though. i mainly just use the brake on steep hills. so i use a combination of both leg back pressure and a little break and i am able to control my speed without any squeaking. one other draw back is that the brake pad is rubbing off on my pretty rim
Geek Extraordinaire
Bikes: Bianchi Advantage Fixed Conversion; Specialized Stumpjumper FS Hardtail
I used a front brake on a non-machined rim. I didn't notice any big decrease in performance. The rim started to look a bit chewed up after a while though.
I'd rather have a bottle in front of me than a frontal lobotomy.
Sintesi Conversion Serotta Track
griffin_
Originally Posted by tbrtbx
a roller skating jam named saturdays.
https://www.youtube.com/watch?v=WFACpd4ow64
Rivendell makes some good points about why non-machined rims might actually be preferable to machined rims, along with some interesting background on how rims are made: https://www.rivbike.com/tires/our_approach_to_rims
It sounds pretty smart, at least. ;-)
I have non-machined rims and my front caliper works great.
Ride for Life
i run a brake on my painted non-machined rims. they start to look nasty after a while. they squeal for a while, but i only use my brake as an assistance for my legs. i've yet to run into much trouble, but i also don't fly around everywhere near as fast as many others i've seen.
BMC Lover
I've got an old Panasonic frame I'm building up and am thinking about some electric blue Deep Vs...by looking at the attached pic, think the Deep V blue matches close to the blue frame?
hunter, gatherer
someone looking at that pic and matching to real-life deep v's = you looking at a pic of deep v's and matching to your real-life bike
BMC Lover
Good point; brain cells have been diminishing
we are 138
https://www.sheldonbrown.com/brandt/machined-rims.html
This doesn't apply to rims with paint, powder coating, or whatever. But for a bare non machined rim there is no issue at all.
This used to be non-machined but it's now worn down to look like machined. Works fine.https://s157.photobucket.com/albums/t...t=IMG_1801.jpg
well, it turns out the wheels i was looking at are painted, not anodized. but i rarely use the brake...
i think i'll just save the extra bit to get some machined deep vs.
thanks for the replies.
dan bones!
Bikes: iro mark v for street, sh itamori peloton for track
i did it when i ran a brake. its fine. from a distance, your rim will look like its machined after about a week of braking. up close, its kinda gross. functionally, i never had a problem, but i don't brake that hard, and when it starts squeaking on you (it will. loudly), people will know you're coming when you roll up on 'em.
but whatever. you could always do machined front, non-machined rear.
