Penny Farthings?
Long haired freak.
Bikes: 2011 SE Old Man Flyer.
Penny Farthings?
Anybody ever build one?
My Metalwork teacher might be letting me build one, I have the whole front hub/drive system figured out but I still don't know what to do about the front wheel. I was thinking about finding an irrigation wheel but I cant find any good pictures of one to know if it would even work.
Any ideas?
I was going to build one of these, but the front wheel is just to small:
Any ideas?
"the bus came by and I got on, that's when it all began...there was Cowboy Neal at the wheel of a bus to never-ever land."
Spelling Snob
Bikes: Panasonic DX4000, Bianchi Pista
Convert a unicycle- the pedals already propel the wheel
The first rule of flats is You don't talk about flats!
Bikes: who cares?
They are commercially available, someone in Cali is marketing them; a friend in PDX is riding one, but that's all I know.
edit - here's a link:
https://www.hiwheel.com/
The google search:
https://www.google.com/search?hl=en&c...rthing&spell=1
Now for something totally different (looks like a photoshop job to me):
The google search:
Long haired freak.
They're also for sale at www.tallbike.com But I don't want to buy one, I would much rather build one. Hobartlemagne gave me an Idea of looking on Ebay for a large unicycle wheel, but I could only find one attached to a uni for lots of cash.
Spelling Snob
Maybe find a unicycle hub. It wont have the 70-some odd holes that most of the penny farthings had but that would be a start.
Spelling Snob
Here's your start- the hubs/cranks page from a unicycle shop
https://www.einradladen.net/catalog/d...070b2a04b5ddda
coasterbrakelockup
Bikes: surly steamroller w/coaster brake, electra single speed cruiser, specialized rockhopper commuter, no-name single speed folder, 700c ultimate wheel, 24" unicycle, specialized bmx lsd, single seat single speed huffy tandem, pink upsidedown parade bike
Coker makes a 36" rim and tire that people have used on mini-penny farthings in the past. It is the largest available penumatic bicycle tire. Any larger and you'd have to go solid and make it yourself.
Bikes: Sngl Spd's, 70's- 80's vintage, D-tube Folder
Maybe a place like this could provide you with information on
where they get the parts for thier rubber tired, horse drawn
carrage wheels ?
https://www.petticoatjunction.net/carriages.html
(scroll down)
carrage wheels ?
(scroll down)
☞-ADVOCACY-☜ Radical VC = Car people on bikes. Just say "NO"
holyrollin'
You might be able to cull a little information from https://www.wuk.at/hochrad/ about constructing the front wheel. German language site, but great pictures.
I think at one time guys were using bulk wheelchair rubber for solid front tires. Don't know if such a product still exists, though.
Pedaled too far.
Quoted: 11 Post(s)
Liked 7 Times
Originally Posted by randya
They are commercially available, someone in Cali is marketing them; a friend in PDX is riding one, but that's all I know. here's a link:https://www.hiwheel.com/
Radfahrer
Penny Farthings are more or less unicycles with an additional wheel. I think it should be no problem to build the hub, since the axle and what's the hub shell of a bicycle hub are one solid piece in a unicycle/Penny Farthing. The bearings are pressed on the axle and held in place by the fork/frame. You could also just buy a unicycle hub, e.g. here:
https://www.unicycle.com/shopping/sho...Hub+assemblies
or here:
https://aebike.com/page.cfm?PageID=30...and=578&type=T
For the fork/frame you could buy regular bicycle lugs and braze the frame.
The spokes are basically a very high grade wire. (The more spokes the easier to true such a big wheel and make it solid enough)
For the rim I would make a wooden mold/profile and then bend a steel extrusion over that. Or I'd just buy one...
Another approach would be to make a Penny Farthing with an internal gear hub or some other form of gears and a 700c or 27" wheel.
e.g. https://www.unicyclist.com/forums/sho...=internal+gear
or here:
TH 1.81 (133kg*62)
TH 1.81 (133kg*62)
Rat Patrol Chicago
Bikes: None, all, it's the same thing
A Brief History of the Rattyfarthing
Ah, yes, the community of home-pennyfarthing makers is small indeed. There's a reason nobody rides these any more. The homemade pennyfarthing offers all of the danger and inconvenience of the old-fashioned Ordinary, with none of the authenticity or money value!
Originally the Scallywags were supposed to be a pennyfarthing gang. Back around 2002 they thought they'd one-up the BLBC. So they made one and after a test ride that pretty much put an end to that idea:
See here
While riding with recreationists in Critical Mass in 2003, I often wished I could make a pennyfarthing. The problem is just where to get a large, fixed wheel- otherwise the bike is very simple to construct. I researched making your own unicycle wheel, figuring I'd just make it larger. I found lots of tales of horror about trying to drill through axles.
Then I saw a picture from Marin County of an odd reverse chopper. The maker had tilted a frame upwards, reversed the bottom bracket, and mounted a seat on the extended fork! The result looked like a chopper that rode backwards. This gave me the idea that I could cheat and skip the big wheel if I just flipped a frame upwards. This was the result:
That's Phippen riding the 5-speed Pickup Styx. He was immediately inspired to make his own (continuing in the Scally tradition). He found a garment rack that was about the right size. He also found a great way to fix the hub- with a high-end kid's tricycle hub, one with cottered cranks so you could swap out adult size.
Meanwhile, in NYC, Greg of BLBC NY was taking a different route- construct a huge wooden wheel, and then power the thing with the rear wheel. He built out a hub with layers of wood until it was fat enough to screw through the spoke holes.
This, like my method, is cheating. I called my bike a "rattyfarthing". The BLBC started calling theirs "Pennyfakethings". Modern ones sold above have five speed internal hubs, pneumatics, rear brakes, all that crap. This is also cheating.
Here's another one:
They got the idea from the famous "three penny farthing", built with a unicycle wheel:
By bike Kill 4, the rattyfarthing idea had spread. The one shown earlier in this thread is great. Here's Conrads:
I showed up with my classy new one, Winifred. This time I used a beach cruiser and bent my own rear armature. The point of this design is that it uses everything from one bike: Flip the handlebars, reposition the head tube, weld the seat on the fork, chop the fork, and there you go. All you need is one small fork and one pipe.
Here are some hints:
-Pennyfarthings are made with 1 degree rake in the head tube. This gives you a wee bit of trail but allows the bike to turn on a dime, which is important because your weight is almost exactly over the axle.
-old ordinaries had a headtube limiter. This is because after the wheel turns a certain amount, the center of gravity of the bike shifts and the front wheel flies backwards at an angle. You really have to see it on an unlimited ordinary to understand what happens- I found out the hard way- but it's quite amazing. The wheel reaches this point and the bike flies backwards, sending the rider straight down. Phippen made his limiter by cutting a slot in the head tube and welding a bolt to the steer tube. I made mine by using wide handlebars that hit the fork (see above).
-another pennyfarthing secret (I'm trusting you to use these for good, not for evil): "Tuck". On an ordinary the rear wheel is actually UNDER, not behind, the front wheel, because the front wheel is so big it carves up and over. This is the key to handling. The more tuck you have, the tighter your turns, the better your ability to stay up on the thing. A long chopper-forked ordinary (see above) will have the turning radius of a freight train.
-when in doubt, turn right.
-a large wheel has a ton of gyroscopic force as well as inertia. Greg's wooden one felt like riding a boulder through Brooklyn. Originally wheels were made large for speed and bumps. Usually it was sized to your inseam minus the crank length. Then they came up with lots of gadgets letting you use a larger or smaller wheel, but I won't go into that craziness.
-These bikes take a header when you encounter a small bump or slight grade. Handlebars in front will trap you in the bike when you slam teeth-first into the pavement, scraping your shins on the handlebars. Multiple injuries led me to forever swear off Pickup Styx. For Winifred, I put the handlebars underneath. Then I discovered an odd result- I didn't need my hands at all to ride the bike. The bars are just there for torque when accelerating or turning. If I hit a pothole, I fly off and land on my feet rather than my teeth. This is also my dismount. Putting the handlebars underneath makes mounting a little like escaping from handcuffs. You step OVER your arms like a frog hopping and then let go of the handlebars and reach back behind your legs.
-put a crash-post foot on your bottom bracket so headers don't fold your chainring.
-The further back from the axle you are, the safer the bike will be, but you'll lose the ability to push down on the pedals and your lower back will kill you on long rides. I've ridden mine hundreds of miles, even in NYC and Boston traffic- it really rides like a no-hands beach cruiser so I'd recommend as short a wheelbase possible with the most upright riding positiong. I went with the coaster brake (less wrecky) and the single speed with balloon tires and this is one classy, smooth ride.
See here
Here's another one:
Rat Patrol Chicago
Lanky Lass
The things you learn! Johnny Payphone, thanks for all that information. I don't know that I'll ever put it to good use, but it's fascinating nevertheless.
East Hill
East Hill
___________________________________________________
TRY EMPATHY & HAVE LOVE IN YOUR HEART, PERHAPS I'LL SEE YOU ON THE ROAD...
coasterbrakelockup
Winifred is amazing.
Took me a minute to figure out about repositioning the head tube.
The crash video is scary. Looks like the rubber came off the wheel at speed. Ouch.
I got to ride a penny farthing at a party once. I was drunk, it was terrifying. I want one.
Bikes: The Swede
Tires
What are people out there using for tires? The cleanest looking one which caught my eye was "Greg of BLBC NY" and his contraption. I guess you could maybe just order rubber strips or something?
You guys should read this:https://www.crazyguyonabike.com/doc/?...c_id=1451&v=Yl
World tour on a Penny Farthing.
I hear penny's are more common down under. They have an OG or two who like to tinker with them and has acess to a bunch of knowledge perhaps. Google "Tougue of Fire" or just pennyfarthing australia...
Rat Patrol Chicago
Could someone make a big wheel out of 5 smaller wheels and a band around the edge?
One wheel is in the center, 4 wheels spin around the first wheel, and a round band goes around the whole thing. Either some gearing would need to be worked out or you could just "peddle backwards".
