to grease or not?
to grease or not?
getting ready to install my Christ King No Thread headset and just wondering weather I should grease the cups before I press them in. Also, wanted to know if I should grease the crown race. Thanks.
Geek Extraordinaire
Bikes: Bianchi Advantage Fixed Conversion; Specialized Stumpjumper FS Hardtail
I put a little grease on everything. Keeps it from seizing and rusting, and will make it easier to take apart if you ever need to.
I'd rather have a bottle in front of me than a frontal lobotomy.
Sintesi Conversion Serotta Track
Are there instructions? Personally, any item (headset cups, sealed bearings) that has to be pressed in and relies on a friction fit to remain in place... I would not apply grease. I would, however, use Loctite 242/243 if the friction fit is slightly looser than it should be.
Quoted: 2026 Post(s)
Liked 1,095 Times
The many headset I've seen installed by a number of mechanics had grease applied to the cups and the fork's crown race seat before installation. I've done the same on all of my headset installations too. Nothing has ever shifted or fallen out as a result.
+1 with HillRider
in regards to usiing loc-tite, Chris King says "We do not recommend using Loc-Tite and/or similar products to make up for a loose fit as the load forces tend to exceed their holding power causing them to disintegrate and allow movement. While they may seem to work at first, they will usually fail in less than a year."
I already used a smear of grease and just installed my first headset smoothly
