touring "coversions"
yack
Bikes: all of them.
anyone else done/doing/thinking/hating/loving/confused with this?
here is my friends. im planning something along the same lines...
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
It would really depend on the bike. You need to look at the geometry of the frame closely before you proceed too far. Relatively new mountain bikes probably won't make as good a loaded touring bike as some of the older ones. Most of the new ones (around 2000 +) have shorter chainstays then older ones. The older ones tend to be rather heavy, too, unless you get into much higher level bikes. Touring bikes don't need to be superlight but they don't need to be pushing 40 or 45 lbs either.
Something else to consider is cost. Refitting a bike for touring can be pouring good money after bad. I've done many, many upgrades and, while it's fun and satisfying, it is never cheap. Not if you are honest about it anyway. If you sit down and really add up the cost, it often works out to be cheaper just to buy a new touring bike.
If you are going to pull a trailer, just about any mountain bike will do. Personally, for off-road touring or combination road/off-road, I'd probably use a mountain bike with a lockable front shock and a trailer before I'd use bags. If I'm going strictly road touring, I use bags.
As for the picture you show, it looks good but I'd probably investigate a different bar. That one locks your hands into one position which can lead to all kinds of numbness problems. A straight bar or a riser both with barends would be a better choice. I've ridden bikes with only one position and, unless you enjoy that pins and needles feeling when you hands go to sleep, I much prefer more hand positions.
Stuart Black
Stuart Black
Bikes: Eddy Merckx Corsa Extra, Basso Loto, Pinarello Stelvio, Redline Cyclocross
Quoted: 336 Post(s)
How about my old school Cyclocross bike turned into a touring bike?
[QUOTE=cyccommute] Refitting a bike for touring can be pouring good money after bad. I've done many, many upgrades and, while it's fun and satisfying, it is never cheap. Not if you are honest about it anyway. If you sit down and really add up the cost, it often works out to be cheaper just to buy a new touring bike. QUOTE]
+1 I've got too much money in this one from the mid-90's "old" Schwinn shop. This Schwinn Transit is almost unique, I've never seen another one, and it was part of Schwinn's last gasp to compete in the LBS market aside from the Paramount. The dimensions are almost exactly those of the Trek 520, with about one inch longer top tube and one-half inch higher BB. You can see it has a lot of miles on it and I can sit it all day, but if I had to do it over again....I probably would not.
Quoted: 336 Post(s)
So convert a bike if you like, or buy a touring bike from a major brand or get a LHT frame/fork and build a new one up yourself. It will all come out pretty much in the same catagory - what you want you can have.
Bikes: 1984 Raleigh Kodiak Touring, 1992 Scott MTB, 2004 Fuji Touring
Gemutlichkeit
Originally Posted by rnagaoka
...loving it. That's one of the cleanest conversions I've seen yet. That black/silver combo is beautiful in my eyes. And those Surly racks are so...utilitarian. I'm wondering if those "North Roads" type handlebars really work to prevent hand problems?
Drops do give the rider hand position options, but that's because with drops, you need them. Properly balanced between saddle and bars, you don't get fidgety with NR's.
See the Trek 930 above. Those are NR's and I use that bike for the occasional century at about the same frequency that use my 520. Until three weeks ago, I had NR's on the 520 as well. Now, it has Nitto B115 drops. The test is still in progress and the NR's are the standard to beat for me. I consider NR's to be the mosty ergonomically correct handlebars ever made.
aspiring wannabe
Bikes: trek 520, thorn nomad, giant yukon, avanti aggressor, bauer racing bike, couple of other projects ...
nice job!!!!
this is my giant yukon that i converted into a low cost touring bike ... this also appeared in the adventure cycling handbook
Bikes: Civia Bryant, Tern Eclipse UNO, Brompton
Some nice bikes guys. Here is my conversion of a Cannondale BB Hybrid. After using this for the past 4 years I would like to give a real touring frame a go to see how different a proper bike handles. I have had no problems with this. The flat bars killed me while on tour until I swapped them out for the trekking bar.
VWVagabonds.com
Converting a Mt. Bike does not have to be expensive. We bought everything for the touring bikes we are using here in Southeast Asia either second-hand or from eBay...
My old tour guiding MTB converted to touring mode. There wasn't much to convert, except for the front rack on the suspension forks.
Bikes: 2015 Scissortail hardtail MTB, 2013 XL Longbike USS recumbent, 2010 Hans Schneider steel randonneur road bike, 2005 Surly LHT;
I decided to get an LHT & build it up. The difference in positioning was remarkable. At 6'5", the geometry of the MTB had 'accomodated' my size but the Surly truly fits me. I've ridden both off & on and find the touring bike is the one I WANT to ride, the MTB conversion is my backup. Haven't toured with the Surly, just commute on it for 50-60 miles / wk at this point. Will tour this coming summer.
But others will tell you their own stories as illustrated below. I myself saved for a year & took the leap to a genuine touring frame & do not regret the investment at all - the pleasure and comfort of the LHT has been worth the ca. $ 1500 I've got invested in it.
centexwoody
They're beautiful handsome machines that translate energy into joy.
centexwoody
Liked 4,218 Times
And you'd probably be wrong. I have seldom seen an over-the-counter touring bike that didn't need a lot of component replacements to make it optimal. Because of that and because touring bikes are pretty rare anyway, you end up building one up from scratch 9 times out of 10. And so the frame becomes only a small part of the equation. In short, you don't actually save anything by buying a complete touring bike.
None of the bikes listed are necessarily optimum and each might need their own tweeks to make them worthy but the tweeks are only going to amount to a few tens of dollars.
I'm not trying to argue against building your own touring bike from anything you have but I just want to caution that it's not necessarily a cheaper way to go.
Stuart Black
Stuart Black
Originally Posted by cyccommute
Most of the production touring bikes that are readily available could hit the road tomorrow with little modification. A Cannondale T-series is tour ready, with proper gearing and equipment. The only addition needed would be a low-rider rack. The gearing is very suitable. The Trek 520 is tour ready, even if it has a little too high a gear. Change the rear cluster to a 14-34 and add a low-rider and it'd be ready for a cross country trip. The same holds for the Fuji Touring or the REI touring bike.
HOWEVER, much also depends on the experience of the owner. A new touring rider will take pretty well whatever is presented and ride with it. It's only after doing X number of miles that some of the shortcomings or personal preferences might become evident, and then the tweaking might start.
The four fundamental areas of change on an off-the-rack bike would seem to me to be: Seat (I would swap out the original immediately for a Brooks); wheels (the best quality rims, DT Swiss of Wheelsmith Spokes and likely LX hubs); rear rack (Tubus for me); and brake pads (Koolstop originals).
As to building up a bike, the cost of the wishlist items would be as much as the frame, and would go along the lines of a Cro-Mo frame (something like a Thorn) and with 26" rims, drop bars and maybe with S&S coupling; a Rolhoff 14sp rear hub; Schlumff Mountain Drive; a SON dynohub up front; Velocity Dyad rims with DT Swiss spokes; canti brakes; Tubus rear rack; Brooks saddle, and French-style front rack, bag and panniers. The Thorn is not a given, as there are plenty of solid Cro Mo MTB frames with good dimensions from the 1980s still kicking around in Australia, in which case the add-on bits definitely would be WAY more expensive than the frame
Just ride it.
Based on my research Trek 700 Multitrack series have same frame geometry as Trek 520. The Trek 700, 720 and 730 have decent asian frames, with the Trek 750 having a double-butted high-end frame made in USA. Trek 750 has pannier bosses on the fork but lacks a 3rd bottle mount - a nitpick IMHO.
Trek 900-series mountain bikes about '97 and older with no suspension forks make great conversions. Again, the 900-930 have decent steel frames, with the 950 being the top-of-the-line double-butted lighter frame.
All of the above will take mountain bike triple cranksets, mountain hubs and derailleurs. Keep the 7-speed cassette and derailleur for what some people say is an indestructible combination. You can mount a 48-38-28 triple crankset (square-taper type), a new front Shimano LX derailleur to give yourself awesome gears. Add some trekking "butterfly" type handlebars for all day hand comfort.
You can apply above logic to many older MTB with a steel frame.
Keep in mind that it matters not so much what you ride, but that you do.
Quoted: 336 Post(s)
DavidARay@gmail.com
Bikes: Trek 920 Fashioned into a Road Bike
Also Mr. Polak, didnt they introduce the 900 series in 92 or 93? I may be mistaken. SET ME STRAIGHT
Liked 4,218 Times
I think we're agreeing. A Cannondale tour-ready bike isn't cheap. Nor the Trek version either. I'm not saying they're expensive. What I'm saying is that generally speaking you're pretty much going to spend between $1K and $2K for a touring bike if you're being careful. You can get it cheaper or a whole lot more expensive but thinking you're going to build one on the cheap without ever having done it before is not going to happen unless you're really a whiz.
Stuart Black
Stuart Black
Scott
Bikes: Too Many
Originally Posted by jcm
Yes, a beautiful job. And, yes, North Road bars do help relieve hand numbness and general discomfort if you have trouble using a more stretched out setup with drops. In other words, if you have back problems or arthritis issues in the shoulders, neck or collar bones, NR's are a great solution. They also help a lot with carpal tunnel problems.
Liked 4,218 Times
Stuart Black
Stuart Black
DavidARay@gmail.com
I started using NR bars recently and I find that with bar ends on them. YEA THEY LOOK WEIRD. They can offer 4 good hand positions. Including if you have brake levers , placing them near the first turn in the bar and then use those as hand rests. That is the most comfortable for me. It feels just like when you rest up on the top of drop bars.
It's not a case of being balanced on the bike but rather being able to change the position of your hands to get blood flowing back to the ulnar nerve.
