Hub overhaul
Dropped
Hub overhaul
Relatively new to bicycle mechanics, but I've been having fun disassembling/breaking/attempting to reassemble some old bikes.
Now to the point. I have two questions:
First, I decided to overhaul the hubs on a 1993 Cannondale road bike with RX-100 hubs. For all I know, this is the first time they've been serviced. Did some research, found that the most common bearing ball size for front hubs is 3/16. Stopped by a shop before opening hub, asked for 3/16 ball bearings, mechanic said he only had 5/32, but that they use them all the time without problem as a replacement in hubs using 3/16. Disassembled hub - existing balls definitely appear to be at least 3/16 (unscientifically measured against a tape), but to the eye appear much larger than the 5/32s. The shop owner has apparently been in business for many years, and was highly recommended by a friend who has had years of good service there. Thoughts and opinions? Is it advisable to use the smaller size?
Second question. Both cones on the front have almost identical gouges, no bigger than 0.5mm, at one point of the ball bearing pathway (see photo). From what I've read, I should trash them in favor of new cones. Opinions? Also, what could have caused this? The axle appears straight. There was no play in the hub when it was mounted on the fork. Any thoughts, opinions, advice, or flames?
Oh, one more thing. Anyone have a spare set of cones for RX-100 hubs? Top dollar/euro/sterling paid, as long as it's under five of them.
Patrick
Patrick
Pwnerer
I personally would not use a different ball size for rebuilding that hub. Bearings are cheap enough, and you should be able to find them at another shop, or even online for just a couple dollars. Heck, go all out and buy expensive "premium" bearings for a smoother hub...the difference is negligable at best, the bearing race having as much to do with quality as the bearing. The RX100 was a cheap hub and you should only expect the according quality.
As for the cones, it looks like a manufacturing defect to me. There are several compatible cones available to fit the RX100 hub. Nice compatability chart here.
Dropped
I know RX-100 is low end, and that's part of the reason I asked the question. Will these gouges have a detrimental or catastrophic effect on the bearings, or might it work okay? I've ridden the bike occassionally (no more than 20 miles/week) with no serious problems, but I don't know when the cones were damaged (if not a manufacturing defect). I was noticing a slight vibration coming from the front, which is why I opened the hub up.
Edit: The old bearings do not show any signs of serious wear, so I question the severity of the defect in the cones.
Thanks to the info you provided, I did find a shop online with the appropriate cones. But with $8 shipping, I can't justify buying only the cones and some bearings. Looks like I might end up with some new tools and maybe a smaller inner chainring.
But the point was to save money! I'll end up spending more than a new hub would cost...I need some fiscal discipline.
Patrick
Patrick
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
Patrick
Patrick
Dropped
The cups seem to be in great condition - very, very minor scratches. The wheels are quite true as well. I've only had to make minor adjustments. But I suppose I'll see what happens as I put more miles on them.
cyclist/gearhead/cycli...
Bikes: Homebuilt tourer/commuter, modified-beyond-recognition 1990 Trek 1100, reasonably stock 2002-ish Gary Fisher Hoo Koo E Koo
JunkYardBike,
The cones are definitely damaged, as you've seen. They may be interchangeable with cones from similar Shimano models: take 'em into a shop, ask to rummage through their parts box, and squint at whatever you find.
The ball bearings may *appear* fine to the naked eye, but believe me, if the cone looks like that they are NOT. Just yesterday I overhauled an old headset and was ready to replace it because it felt so rough. The ball bearings looked perfectly shiny and new, but I tried replacing them anyway. $1 worth of bearings later, the headset was running flawlessly smooth. The moral of the story is: bearing damage can be invisible to the naked eye. Do yourself a favor and get new Grade 25 bearings in the right size. Absolutely *the best* $1-5 maintenance you could ever do on your bike!
Quoted: 2026 Post(s)
Liked 1,096 Times
DO NOT use the wrong size bearings! I can't believe your LBS recommended 5/32" bearings when ALL Shimano hubs I've ever seen use 3/16" balls. You definitely need a new mechanic. You may be able to get the proper size balls at an auto parts shop and certainly at an industrial supply house (Granger, McMaster-Carr, etc.). Get Grade 25 balls, not Grade 200 or 300 (lower numbers are better).
You need new cones too.
Good quality bearing balls and cones can be obtained mailorder from Bike Tools Etc.
Quoted: 1163 Post(s)
Liked 442 Times
Patrick
Patrick
Why guess at the proper size of the bearings. Get your self a 1" micrometer and learn how to use it. This is invaluable for all kinds of mechanic work. You'll be able to I.D. the diameter down to thousandths of an inch (or even 10 thousandths if you have the right model of mikes). If you don't feel comfortable with converting thousandths to fractional measurements, the machinist market is flooded with good quality dial calipers, some that are marked on the dial in fractional measurements to simplify things. Its odd that to work on bikes you need BOTH a fractional and metric dial caliper or micrometer. Once you verify the correct size ball bearings then you can deal with the BOZO mechanic who recommended the wrong size and confront him with his bad advice directly because you will no what you need with no uncertainty at all.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Dropped
Not that I'll ever go back there again.
Thanks for all the help!
