Removing Braze-ons...
Old 06-13-06, 08:31 PM
iamtim's Avatar
Bikes: 2012 Motobecane Vent Noir; 2016 Mercier Kilo TT Pro
Quoted: 30 Post(s)
Liked 4 Times in 3 Posts
I just procured a classic Nishiki International frame, in my size, with which I am going to replace my current, wee bit undersized frame. I purchased this frame specifically to be used as a fixie, so I'd like to remove the braze-on cable ends and whatnot. What's the best way to do so? Will a Dremel handle it? Or should I try and wrap the frame around a wheel grinder? Maybe a chisel to the brazing?
Thanks!
iamtim is offline
Old 06-13-06, 08:35 PM
yo yo yo yo yo
dremel will work fine but be careful.
trons is offline
Old 06-13-06, 08:40 PM
crotchety young dude
el twe's Avatar
Bikes: IRO Angus; Casati Gold Line; Redline 925; '72 Schwinn Olympic Paramount
Dremel. Although I simply pounded them off with a screwdriver chisel.
Originally Posted by CardiacKid
I explained that he could never pay me enough cash for the amount of work I had put into that bike and the only way to compensate me for it was to ride the hell out of it.
IRO Angus Casati Gold Line
el twe is offline
Old 06-13-06, 11:24 PM
Team Beer
Cynikal's Avatar
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times in 104 Posts
Get a propane torch and heat them up. It's way cleaner than a dremel of a grinder plus you won't worry about grinding thru the tube. A torch is how they got there and a torch is the best way to get them off.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Cynikal is offline
Old 06-14-06, 01:28 AM
WTF?
Bikes: trek cross, gt mtb, khs track
if you actually want the entire braze-on off, and have a propane torch, go with a torch.
if you have very steady hands and are patient you could probably do it with a dremel.
if it were me, i'd probably use the dremel and take off most of the braze on and just leave the base so i don't risk cutting into the tube. or you could use a dremel for most of it and take the base off with a file. you'd be surprised how well a properly used file works. just take your time and check the progress after every stroke or two.
now that i think about it, the dremel/file solution would probably do the least damage to the paint. so i'd do that.
mrbertfixy is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
