Tips on removing oxidation from spoke nipples
I purchased an old set of Ambrosio Metamorphisis wheels with DT spokes and Campy Record hubs off ebay that are pretty nice except the spoke nipples are pretty grungy looking. Does anyone have any tips on how to remove the black oxidation from chrome plated brass spoke nipples and the ferrules on the rim? I dread the idea of replacing them one by one but my anal retentive personality may cause me to do it.
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times
buy a can of brasso (cotton wadding stuff) should clean them up just fine.
Marty
Marty
Sono pił lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
I tried Simichrome and that didnt seem to work so I'm not so sure the Brasso would work either. Maybe I'm wrong. Anyone else got any ideas????
Quoted: 113 Post(s)
Liked 16 Times
i would use superfine steel wool. or brass wool as most people here will suggest. Steel being to abbrasive.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
Dolce far niente
Quoted: 20 Post(s)
Liked 15 Times
"Love is not the dying moan of a distant violin, its the triumphant twang of a bedspring."
S. J. Perelman
S. J. Perelman
Bikes: Heron Wayfarer/ 2004 Giant Cypress SX
"Never-Dull" impregnated cotten wadding in a can. It may be sold now under the name,"Eagle One" Sold at Auto Zone or I'm sure the net. Works wonders on removing surgace rust on spokes.
Richard
Richard
Seńor Member
Quoted: 1491 Post(s)
Liked 1,072 Times
The other suggestions may well work, but if all else fails, there's 1000 grit wet/dry sandpaper.
OldBikeGuide.com
Some hardware stores and 'dollar stores' have a small brush about the size of a toothbrush that has a wooden handle and brass wire 'brushes'. These are prefect for cleaning up spoke nipples.
juneeaa memba!
Bikes: Crap. The box is not big enough...
Quoted: 13 Post(s)
Yo! Hold on there! depending on the finish of the rim, the brass wire may scratch the rim, and that'd be bad. I use a wheel holder in a vice, and a long strip of cotton sheet to make a polisher. Then, depending on what is on the top of the pile I use mothers or blue magic on the rag, take a wrap around the nipple, and go back and forth a few times like dental floss. I clean the spoke in the same way...Takes about 10 minutes/wheel.
Rusty wheels
H
Hello, I'm not an expert but my steel wool ,my rotary tool,pieces of sand paper, all will work as long as we don't get in the mood if expecting extremely shining results,I sprayed wd40 to everything and this morning I wiped it off.
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
just take the wheel apart, clean all the components properly, and re-assemble.
Quoted: 1627 Post(s)
Liked 629 Times
Yeah, WD40 and a brass brush. You can work at an angle so that the brush never really touches the rim itself, or at least only in glancing manner.
Still learning
Quoted: 241 Post(s)
100 silver brass DT nipples cost $9.
https://www.niagaracycle.com/categor...les-box-of-100
You can just replace them one by one.
You should true the wheels anyway.
Quoted: 2432 Post(s)
Liked 638 Times
A dremel with a wire brush. I had a set of wheels with corroded nipples and rim eyelets and the dremel got them looking brand new very fast. Didn't scratch up the rim at all.
