clydesdale tire wear
www.onecycles.com
This spring as I was slobbering on and wanting to ride my good bike, I noticed that the rear tire has shown what I think is a lot of wear. There is actually a flat surface on the contact surface of the tire. The tires were brand new last fall on a brand new bike that only got about 700 miles last fall. I would say that 60-70% of my riding is on asphalt, and the rest would be chip and seal and other marginal paved surfaces.
the tires are continental gp 3000s, size 23, and I always make sure they are to 120lbs before I ride, b/c I weigh 235 and don't want any flats (still got one though).
after this I checked my SS tires and the rear hadsimilar wear on a 23 michelin megamium. but the ss is not a good comparison b/c I frequently ride it with my work crap and man purse items which surely total 30+ lbs sometimes. and on rougher surfaces....
FAT KIDS: What is a good high mileage tire?
also: is this site slow on anyone else's computer? I look at pictures all the time, movies, all that good stuff, and it never tires out my computer like bikeforums.
He drop me
Bikes: '03 Marin Mill Valley, '02 Eddy Merckx Corsa 0.1, '12 Giant Defy Advance, '20 Giant Revolt 1, '20 Giant Defy Advanced Pro 1, some random 6KU fixie
Quoted: 138 Post(s)
Liked 12 Times
I weight in at 220lbs and I ran through a set of Kenda Koncepts in 500 miles...tire is just too thin. I really like the Vittoria Rubino Pro Slick but even that tire I get less than 2k miles...I think I got 1700 miles on my last set but they stick like glue and I never flatted with them...great ride feel too.
The views expressed by this poster do not reflect the views of BikeForums.net.
Bikes: Bruce Gordon BLT, Cannondale parts bike, Ecodyne recumbent trike, Counterpoint Opus 2, miyata 1000
235 on 23s'? Running the tires at such high pressure and such weight on skinny tires on non smooth roads. 700 miles sounds good. I ran 38s at 90 PSI on similiar roads with a 240 to 260 lb load and got 7000 miles. On really good roads I will go thru the first layer of tire threads before changing tires. Now I change tires when I start getting 4 to 6 flats a week. 38s for winter commuting 32s for summer fun.
www.onecycles.com
googling right now
I really like the conti ultragatorskin but found that at 1500mi the rear (700X23c) was really squared off. By 1800mi it was toast.....I put a gatorskin 25 on the back and seem to get a lot better wear, but it is only very slightly wider.....I can not say that it is slower or noticably heavier. weigh 190#.
Bikes: Surly Cross-Check, '85 Giant road bike (unrecogizable fixed-gear conversion
Bontrager race lite hardcases. They ride like hell (get 28's, especially if you have an aluminum frame) but last forever and never flat.
Clydesdale
Bikes: 2002 Bianchi Bergamo
I have some Conti Ultra 2000s. I have just over 1000 miles on them, and they still look pretty new. They seem to have decent wear, but IMHO, suck ass in puncture resistence. Three flats, although one was a pinch flat that I cannot blame on the tire. The other two were goatheads.
And yes, sometimes BF runs very slow.
Bikes: Litespeed Ultimate 2006, Litespeed Pisgah , Specialized Roubaix 2008, Trek Madone 2011
I weigh 235 and run Conti Gp 4000's X 25 @ 100 psi front and rear and get over 2000 miles out of a set. The rear squared off at about 1200 to 1500.
"Purgatory Central"
I weigh around 240 and got about 1300 miles out of the Conti 'Gatorskins' (23mm)
Switched to Conti 'Ultra 2000' and got about 1700 miles from them. Good tires too. Only had two flats with them. I think I'll try the same tire in 25mm.
Bikes: Merlin Cyrene, 1989 Nishiki International, Specialized Stumpjumer M2 Hardtail, ProFlex 856 Full Suspension
Incidentally, I didn't like the Conti 3000's, switched to Vredestein Fortezza and I like them so far , although don't know how the'll wear since I've only got 600 miles on them.
I weigh about 240, and I haven't used anything smaller than 32cm tires (my Atlantis has room for HUGE tires) in years. For everyday riding and commuting, I go with 700x35 Panaracer Paselas. I don't keep track of tire mileage, but I'm sure they're going at least 4000 miles (I rotate when I think of it, maybe every 500-1000 miles). I'll never go back to skinny tires in any case--too harsh riding and dodgy for me.
I think Velo Dog has the answer. There are so many Clyde threads about wheel problems, yet it is seldom mentioned how many wheel problems are the result of running inappropriate tires with inadequate air volume. Anorexic rubber is not for Clydes. Oh yes...they are so sexy and trim-looking. With bigger bodies and bigger bikes, the last thing a Clyde needs is more rolling resistance, right? Nope, wrong argument.
When clinchers first started to replace tubulars, everyone thought that thinner was better and it was common to see 19 and 20 mm clinchers in the 80's and 90's. Finally people realized how harsh these things ride and the industry more or less settled on 23 mm as the industry standard...for standard-sized people, that is. I don't think that anyone who weighs more 175 lbs. should ride anything smaller than a 25. If you weigh over 210, you probably don't want anything smaller than 28's. Bigger riders don't need tires with higher pressure, what they need is a tire with a higher air volume. Don't be fooled by theoretical rolling resistance arguments: if you want to experience the performance that a 155 lb. rider gets from his 23's, you need to ride 28's or larger.
Here's another personal preference: I used to rotate my tires to equilibrate wear, but now I just buy them in sets of three. For me, the rear tire wears at about twice the rate of the front, so I just replace the rear one when it's worn. By the time the second rear is worn out, the front is ready to go as well.
Bikes: Mongoized Norco with roadie components
I use Michelin Transworld City (1.5" & 90psi) I am 234, so with fanny pack, water and bike about 260lbs. I have 3000KMS on the rear and its starting to look a little tired. I think it will give another 1000 or so before I swap the front for the rear, I run exclusively on fine asphalt cycling tracks.
On my TARDIScycle!
Bikes: Trek 520, Trek Navigator 300, Peugeot Versailles PE10DE
Quoted: 5 Post(s)
Interesting...I weight a lot more than you (just over 300) and I've never noticed any tire tread problems. I've only used stock tires. I did change my comfort bike to slicks (probably the tires with most mileage) and I bought cheapest ones in the shop...still never noticed any problems.
UareFASTjustNOTfastENOUGH
Bikes: Scott Gambler, Scott Ransom, Bianchi C2C 928
I tend to notice more wear with the tires on my mountain bikes then my roadies which I would expect because of the knobs on the mtb tires. They are softer and so wear quicker.
When I was racing, DH, I would go through a set of tires every weekend. Not that they would wear a flat spot but rather the knobs would tear off in the high speed corners. My XC tires would last me about 2 to 3 months which was about 1000mi. Both my DH tires and XC tires were Nokian NBX's.
On my road bike I ran Vittoria Rubino Pro Slick 700x23 inflated to 120psi and would get an easy 1000+ miles on them when I was 290 which I thought was prety good. Before that I was only riding on tubulars and they lasted even longer. With the tubulars I was using Continentals (forgot which model, its been about 5 years now, but it had a max psi of 220) and I kept them at 180.
One thing to keep in mind is where and how you are riding. If you do a lot of stright line riding, meaning not a lot of work in the canyons, you will tend to get a flat line down the middle a lot quicker. Plus, if the roads you ride are rough pavment it will cause even more wear then say a new blacktop.
MSF
MSF
I don't have a mileage figure because I didn't have a cyclometer at the time, but Panaracer 35mm Pasela TourGards did well for me. They also were very puncture resistant. I'm trying a set of Avocet Cross K 35s this time around. The reports I've seen talk of remarkable mileage, great puncture resistance, and, according to Bicycle Quarterly, they have a pretty low rolling resistance, too. The only problem with them is that they're hard to find. I got mine from Harris Cyclery (home of Sheldon Brown).
Makes It Look Easy
Bikes: I own three.
Like I said in previous posts, Conti Gatorskins are a favorite of mine. I push 300-400 miles a week, and have to replace those jawns every 3-4 months or so. I also weigh 235 with added weight from packages and tools and stuff... so, in my mind... that's one hell of a tire.
Coblstones=Balls o' steel
+1 for conti gatorskins. I am 6'5" and about 225lbs. I prefer the 28mm size and i am pretty rough on them. No issues....
My Specialized Armadillos (700x28 in rear and 700x25 in front) have about 1500 miles and still look pretty good. I've been happy with them and only had 1 flat in that time, and that was a big nail.
Bob
Bob
Crawlin' up, flyin' down
Quoted: 1020 Post(s)
Liked 2,509 Times
I have heard good things about a number of the tires discussed, but have no experience with them except for the Armadillos, which I have had good luck with. But I have recently installed some Rivendell Ruffy Tuffy's, and I love 'em. Smooth? Like buttah. They also have a wonderfully round cross-section, which makes 'em corner ever so nicely. (And I ain't sayin' it because Grant Peterson says it, but because it's true.) So add those to the list of possibilities. Caveat - they only come in one size - 700c x 27 or 28 (depending on whether you believe Rivendell or Japanese bureaucrats).
I haven't noticed a huge difference in average speed compared to my road bike with 700x25's...maybe .5 mph over my typical training route but I have different cyclocomputers on the two bikes (will be remedied soon so I can get a better comparison). The only difference I've noticed is the increased comfort and smoothness though this might be partially due to differences in frame qualities (Bianchi Veloce vs Cross-Check). I'll probably try 700x35's when these wear out. I believe Sheldon Brown and others have pretty well debunked the idea that larger tires have significantly higher rolling resistance, if properly inflated. I personally can't see the logic of a clyde running anything smaller than 700x25's, unless you just can't get tires you like in that size.
No one carries the DogBoy
I have ridden conti gatorskins in both 23 and 28. There is VERY little difference in effort/speed. The 28s run more like most 25s anyway. I found that tire wear was significant around 2000 miles and replaced them with the 23s. The 23s now have about 1500 miles and look fine. The least wear I ever had was 700-28 nimbus armadillos, but they also weighed a ton. They finally met their match in a draw with the snow-blower...(they were off in the corner of the garage while I had the studs on the bike, somehow ended up getting pulled out into the driveway and it snowed....bye-bye armadillos...bye-bye cheap snowblower.
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
Second issue, the softer the rubber, the faster the wear, soft sticky rubber can wear out in nothing flat, so you want a harder compound tire then the one your using, mind you it will have less grip as well.
Third, rear tires wear faster then fronts do, to get best use out of your tires, when the rear one wears out, get a new tire, put it on the front, put the old hardly worn front tire on the rear. This way you always have the best tire on the front, a blowout on the back, means a bumpy stop, maybe a skid out, a front blowout means loss of control and a possible face plant, and those hurt If you want to find out, how I know a face plant hurts, see my blog.
