Need help with Ultegra cranks
is slower than you
Bikes: Gunnar Sport, Marin Pine Mountain, Gunnar Ruffian, Gunnar Roadie, BMC Fourstroke, Salsa Vaya
I'm hoping this isn't a double post, but my previous try seems to be messed up. Anyway...
I'm hoping someone has an idea to help me out here. Last season I bought a new bike with Ultegra 10spd triple setup up front (Hollowtech external BB). Almost right away I noticed the cranks weren't spinning as freely as they should---there's a fair amount of resistance. With the chain off, I'd give the cranks a spin and they'd quickly come to a stop after making one revolution or less. All of my other bikes' cranks spin much more smoothly, and if I give their cranks a good spin, they rotate freely for at least four revolutions.
Shortly after I got the bike, I took it in to a couple shops to see what they thought. They admitted they didn't have much experience with the new Ultegra stuff but suggested it might just need a break-in period.
Now, a year later, the "breaking-in" hasn't done anything to free up the cranks. They still don't spin freely and will only make one revolution or less when I give 'em a push.
Any input?
Any input?
Proud supporter of the Chippewa Off-Road Bike Association (CORBA)
www.chippewaoffroad.org
Quoted: 303 Post(s)
Liked 136 Times
Probably a reflection on the sealed bearings used in the cranks. Sealed bearings have built in drag that is a lot more than open bearings. Possible that there is some binding somewhere in the system, would be useful to compare with another bike. Finding a bike at an LBS with a similar setup shouldn't be hard, but if you are rotating with the chain off, a direct comparison will require supportive LBS personnel.
Steve
Steve
is slower than you
Steve: It doesn't seem like just the difference between cartridge and loose bearings, so I think I will just take it to the LBS again for a comparison. They're pretty good guys, so I'd expect they'd pop a chain off if necessary.
NoRacer: BB was brand new (as was everything else on the bike)
Direct Hit Not Required
Bikes: Leopard DC1, Ridley X-Fire, GT Zaskar 9r
Perhaps the pre-tensioning cap was torqued down too much.
Loosen the crank arm bolts and loosen the tensioning cap. Does it spin better?
If so, torque the tensioning cap to 6-12 in/lbs and retighten the crank arm bolts.
Now does it spin more freely?
is slower than you
I'm actually in the process of overhauling the whole bike anyway, I just haven't picked up the proper tool for removing the cap and BB yet. Once I do I'll try your suggestions. How do I know the torque on the cap if I'm using the Park tool (BBT-9)? Just estimate?
The tensioning cap (Crank Arm Fixing Bolt on Shimano Exploded View) is something that you just have to go by feel. 6-13 in/lb is not a lot of torque.
I-M-D bell curve of bikn'
Bikes: 06' Jamis Eclipse in the making.
Mine spins freely a few revolutions..........your's should too. May need to take off the crank and take a look at your BB.
Ego Campana Inflectum of Circuitous
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Mine also spins "freely" - a few (<10) revs. I did notice that there is definitly more drag using this sealed cartridge bearing design than I am used to with bottom brackets. So much so that when I first stripped my bike after it was originally installed I assumed that the original builder had not adjusted it correctly....wrong. You know what the say about assuming....it makes an...well you get it.
Adjusted correctly these things just have a lot of internal drag...due no doubt to the viscosity and volume of the lubricant of choice. Oh well. The eingineer in me says "Drop the whole 'feel' thing and pick up a torque wrench, spec, and ride" While the lost art, locksmith side of me says "it just doesn't feel right"
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
My cranks also spin freely. What I would add is that my XT cranks (also HT2) were noticeably quite stiff when they went on and now are much more free at the BB, 500 miles on.
Note too that Shimano offers no wannranty on BBs whatsoever. A friend of mine had his for only 5 days before it needed replacement; Shimano said, "sorry, there's nothing we can do" and he had to buy another.
Bikes: Trek 7300FX, Lemond Sarthe
Originally Posted by Peek the Geek
BlastRadius,
