Hollowtech-2 Crankset Axle Length
Old 03-06-12, 09:18 AM
knight9413's Avatar
Bikes: Vintage Fuji Del Rey, Torelli Countach, Mondonico Diamond, All-City Mr. Pink, Mikkelsen Custom Road Bike, Surly Ogre, Dahon Helios, Marin Muirwoods
I am trying to install the Shimano Alfine crankset into my Soma Juice 29er. As you can see from the pic, the crank's axle length (68mm) is too short. The bb shell width of the frame is 73mm, and this is a Shimano HT-2 crankset. Maybe I need a different crankset, but I am thinking this crankset/frame combination might work because I've seen pics of the crank installed in this frame. I'll attach pics for reference. Please let me know if I am explaining this clearly, and thanks for helping.
knight9413 is offline
Old 03-06-12, 09:21 AM
Bikes: All-City Mr. Pink, Kona Jake CX, Niner ROS9
I can't tell from the picture, but do you have shims installed between the BB shell and the BB Cup? If so, remove those.
SER71 is offline
Old 03-06-12, 09:23 AM
AEO
AEO's Avatar
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times in 5 Posts
is there an off chance that the crankset is a special order for 73mm shells?
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
AEO is offline
Old 03-06-12, 10:03 AM
knight9413's Avatar
Hm... not sure. Do I need to remove the bb to find out? I hope these pics can give you a better picture.
Old 03-06-12, 10:05 AM
knight9413's Avatar
I've also seen another bike with this setup.
Old 03-06-12, 10:11 AM
mechBgon's Avatar
Liked 6 Times in 5 Posts
The Alfine crankset is for 68mm bottom-bracket shells, according to Shimano. One option would be to have your BB shell milled down from 73mm to 68mm.
mechBgon is offline
Old 03-06-12, 11:27 AM
Bikes: 8
Liked 1,363 Times in 868 Posts
OTOH, You might just get the MTB crankset for the 73 wide BB shell,
then set it up as a single speed ,
by buying a different set of chainring, and a chainguard ..
given the BB axle is part of the right crank arm these days, on the latest designs..
fietsbob is offline
Old 03-06-12, 11:53 AM
The spacer would be between the drive side cup and the BB shell.
SER71 is offline
Old 03-06-12, 02:01 PM
mechBgon's Avatar
The road BBs don't come with spacers, either.
mechBgon is offline
Old 03-06-12, 02:28 PM
knight9413's Avatar
Right, getting another crankset is the way to go... just curious how the other people with the same frame did it.
Old 03-06-12, 02:34 PM
There are two different type Alfine crankset.
Single and double chain guard type. Double chain guard type has 9.5mm longer axle.
If you remove inner chainguard and 1 spacer it fits 73mm shell.
https://techdocs.shimano.com/media/te...9830637968.pdf
hartsu is offline
Old 03-06-12, 03:45 PM
knight9413's Avatar
Really helpful information. Thanks so much!
Plainsman
Bicycle Mechanics
27
08-10-19 08:06 PM
jpvjr71
Bicycle Mechanics
5
01-03-18 03:46 PM
cricket1116
Bicycle Mechanics
2
09-30-14 07:42 PM
RobbieTunes
Classic & Vintage
22
06-19-13 07:29 AM
ruskko
Bicycle Mechanics
19
10-31-11 11:28 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
